4.0L High Output 6 cyl engine getting ready to be pulled from running and driving 94 Wrangler. Engine will include intake and exhaust manifold/ throttle body , distributor, alternator, starter, power steering pump, flywheel, clutch, and trans inspection plate. Many brand new parts also just installed. New t-stat and housing, water pump, idler pulley, serp belt, and plugs. No wiring harness or ECU included in engine price but available for the additional listed amount. Still able to hear it run and drive before its pulled next weekend. Mileage is not know but shows normal oil pressure on gauge cluster. Has typical valve cover and probably oil pan or rear main leak that is easily addressed prior to install Sold as-is. Engine $600 Entire under hood wiring harness from bulk head connector onward. $150 Rebuilt original ECU by Cardone in May. $150 Engine , entire under hood harness, and ECU $850 firm. Local pickup only in 60451. Will not ship. ECU and harness will not be sold individually until engine is sold. Pm me if interested.
