Hey all lately I've noticed that my stroker has a set of nuts at cold start but after a while i got no get up and go. Any idea.
Also did an oil change last month used a k&n oil filter and noticed that my oil pressure is 0 psi until i get worm for about 30 min then it will shoot up. Also noticed while under the jeep that from my front axle to my rear was covered in oil think its a leak but no sings of oil on the deck.
Please any help would be grate.
What weight of oil you running? Sounds like your running really thick oil and blew out a seal.
So first off check your oil pressure sending unit its right by the oil filter. Make sure it has good connection. Could try replacing it. If no change then oil pump replacement.
As for your oil leak sounds like you got a the rear main seal out. This is a very common issue with the 4.0L
