Hard time to replace the cap, rotor, and 8mm wires for the HEI dizzy on the 4.2s with online speed shops in Canada.
Part numbers for the wires, nowhere. options; measure and crimp an 8mm set at $175.00!, only in a V8 set.
If you have crossreferenced or know of a Cap, rotor, and wires for 4.2 or 4.0 with brands you are using on your rig pls post.
Motor vehicle Gas Automotive tire Auto part Electrical wiring
and or know
Look for Accel for build your own wireset off amazon if available up north.
Does Summit racing not deliver to Canada?
Discussion Starter · #3 · (Edited)
Yes, Summit does. add on duties, currency, and shipping. Looking for a crossreference from a 6-cylinder GM car for the cap with HEI, do you know of one Got it?
Great tip on the wire set! Thanks.
Rectangle Font Parallel Number Screenshot
You want 8mm wires for HEI, go 4100 series kits for 8mm.
See if you can find a 80's 305 chevy. They are all going to be about the same. Try a 6 cyl mustang.
I'll do a little browsing for you in a bit when it slows down at work.
Reactions: dougiet
