There are far, FAR better V8's than the gutless, spark plug spitting, PITA to work on Triton. That's my opinion anyhow.
x2there are far, far better v8's than the gutless, spark plug spitting, pita to work on triton. That's my opinion anyhow.
x2...good luck fitting that wide load between the spring towers.Better measure that beast. It is really wide across the top. My guess is a lot is going to be moved. And the trans/tcase package is something to think about. You have a pretty short rear shaft to work with.
good ideathank you for the input guys i think i am going to just part out the f-150 get as much as i can and just get the stroker kit ive been wanting. less hassle and good power without having to go crazy changing everything
4.6 will run foreverThe plug issues were more related to the 3v engines (and it seems the 5.4 was more prone to it). The 2v’s were pretty solid, reliable engines.
They were gutless as hell though, but man they may be one of the best sounding engines ever made.
And while it is always a possibility, I’ve never had an issue with it. And I’ve had five f150’s and four mustangs. Granted, of those only three were the 4.6 and only one was a 5.4. Only “plug” issue I’ve ever had was just trying to ACCESS the rear plugs cuz the engine is set so far back.
They are incredibly reliable, always have been!4.6 will run forever
my next door neighbor is a maryland state trooper. back when they had crown victory's because he was K9 he got the high mileage cars they all had a couple hundred thousand milesThey are incredibly reliable, always have been!
