So I am in the middle of a slow 4.6 build and am researching camshafts. I know that Crane took a lot of flack in the 07-09 range with camshaft failures in strokers. Does anyone know if their product has gotten any better since? I see that Titan is now using Crane camshafts in their pre built strokers (looks like they were using comp cams back in 07-08). Anyone with any experience in this topic would be great.
Thank you
Crane Cams
I built a 4.7 for my Wrangler and put in a new Crane cam and lifter set. After about 12,000 miles one lifter failed. The top flat sheet metal plate wore through and the debris plugged the check valve open. The lifter was down all the way. I put in a new Crane lifter, but am concerned that they will all fail.
