1 - 9 of 9 Posts
I want to put a 4.7l v8 out of a Grand Cherokee into my TJ and I want it to be an automatic. Does anyone know all the things I need to do this?
It is NOT the same.. The 5.2 is the old Magnum series and is based on the really old 318 motors which started back in the early 70s.
The 4.7 is known as the "baby hemi". The only things it has in common with the 5.2 is that it has 8 cylinders and runs on gas.. That's pretty much it. If you're gonna go all that work, why not do the 5.7 hemi.. It's the same amount of work to get it in and functional. The only difference may be the cost especially if you are getting the little motor free of really cheap..
The 5.9/5.2 conversion is actually the simplest swap to do. Lots of common parts between the two and it will be cheaper to finish than any other V8. Time to google and start your research
I had the 5.7 Hemi in my 2004 Ram 2500 and it would make that vehicle jump. One in a TJ would be scary.
Nah... It's a lot of fun..👍
When swapping ZJ or WJ V8 to TJ make sure both use same bus
For TJ 97-2000 is CCD bus two wire twisted pair
2001-2006 TJ are PCI bus single wire
ZJ (so thru 1998) grand Cherokee are CCD bus
Easy to spot as door handles have a push button
WJ which came out in 1999 are all PCI bus
Easy to spot as door handles pull up
XJ 97-2001 are all CCD bus and no XJ after 2001
All the 97-01 XJ have no front door vent window (the little triangular window on early XJ)
1 - 9 of 9 Posts
