· Retired Moderator
97TJAC said:
need a set of arms for a 4" lift suspension for a 97 Wrangler SPort
You might want to be a bit more descriptive of what youa are looking for. Are you looking for adjustable control arms? Uppers? Lowers? Front? Rear?
true true
ok i just put on a set of coils from a 4" lift
i am new to the jeep lifting so would that mean i need uppper/lower front/rear?
· Retired Moderator
97TJAC said:
true true
You are right. The CA angles that a 4" lift puts your stock arms at would definitely lend to wanting adjustable Control Arms. IMO you would want to start with rear adjustable uppers/lowers first (helps correct pinion angle for Dshaft). Then move to the front.
I have the arms that you need. It is a tera flex kit that was used for approximately a year and a half and was replaced with a long arm kit for more extreme lift. It includes Rancho shocks, but either one or two are not good. I can send you a pic of the kit if you would like it. $250.00 plus freight from 93257. Steve
