1 - 10 of 10 Posts
rebuilding my suspension from several different components i'd like to see how much there is to work with using these springs and body lift with 35's
*moved to TJ General Discussion for better response.
I'm not "in tune" with everything TJ, but others will chime in and help. Can you tell us what else you are working with? Is there a lift on it already? What other components are you planning on using? Just 4" springs alone aren't going to cut it...
Is that a question? 4" Pro Comp springs with a BL will clear 35s. The springs are about the only good Pro comp suspension component they make.
Reactions: ridinsurf66
Yeah this was supposed to be a picture request... the springs are like you said literally the only thing I am using from pro comp
Ok, I'll move it over to PICS and adjust the title...
4" springs with a 1.25" BL and 35s.
that combo plus a 2" spacer in front clears my 38's
*every wrangler ive ever lifted needed some sort of spacer in front to account for shitty factory rake and winch bumpers
4" coils with a saggy 1.25" body lift and 35s (34.8")
1 - 10 of 10 Posts
