If the linkage is hooked up to your T-case shifter, and all is good in that department, and it still won't move, chances are your transfer case is messed up as well. That is very common when shucking the driveshaft at highway speed. I would check the transmission while your at it. The vibrations can go all the way into your transmission, causing damage throughout.
