I just had a 4 wheel alignment done after a repair from a minor fender to my wheel accident. Attached is the spec sheet from the alignment. Is it good? Is it Bad? Help me understand please. I know I should have asked the guy who dropped it off but I wasn't able. Thank you for any insight.
2013 2dr Wrangler Sport
2.5" Lift with 35" Tires
Your #'s look fine.
Your toe has been adjusted fine but your caster is a little low. If your jeep drives fine leave it. If it is a bit flighty add some adjustable lower arms or drop brackets
Looks fine to me ... What's the issue ?
No issues. I had the lift kit installed but they didn't do an alignment. It drives the same as it did before I got it. I just wanted to know what the numbers mean and if it was up to spec.
It drives great. But I do plan on upgrading my lift over the next few years and these are on the list. Thanks
