I have a 1998 Jeep TJ and noticed that the 4 wheel drive lever is frozen in the off position. The car otherwise shifts through the normal gears no problem. I would appreciate any suggestions. Thanks Carol
Hahaha I just had the same problem. Did have a t-case drop installed and removed it? if so that is the problem you need to put it back in to correct the angles of the your linkage.
