1993 wrangler yj and drive shaft is locked in but no 4 wheel. Don't know much about vacuum actuator. How do i test to see if it is bad. do i put on a new pump or go with the cable system i am see around. Also i get a bad vibration at 50-55 when i hit a bump n the road have to slow down to 35-40 to get it to stop
here is the only good way to fix your problem.
it completely takes the vacuum actuator out of the system and makes it like set up like the later jeeps are.
you will not notice any change in handling, mpg, wear issue's but you will have fwd every time you need it like jeep intended.
the transfer case is the main disconnect to the frt axle any ways it never made since to have the actuator .
i have had mine set up like this for years with no problems and neither will you.
http://www.wranglerforum.com/f8/vacuum-shift-motor-inexpensive-fix-w-pics-127405.html
