Is it hard for any other cj7 owners to put their jeeps into 4wd. I have to push te shifter type thing really hard. It will eventually go in after I start moving a little bit but I wanted to know if this is common?
When I bought my jeep it was like that. Someone had actually cut and welded the handle for a better angle. When I switched my 20 over for my D300 it was like night and day. My 9 mo. old could probably put it in gear...slight exaggeration.
Probably hard for abuse...I don't know if flushing it would help or not.
Mine is also hard to put into 4wheel drive very very very common and if you wanna change your fluid it's reallllllllllllllllly easy just use ATF and no it will not improve it
