1 - 10 of 10 Posts
I have a 2003 TJ with the auto. So I know that heat kills an auto Trans. My question is would an auxiliary cooler be worth the money. Not no fancy one with a fan either. Just an aluminum cooler that is spliced into the return line. Will it make that much of a difference on keeping the Trans cool and extend the life of the Trans? Anyone ever install one? If so pics would be nice.
Administrator
Are you sure you don't have one from the factory? I replaced the stock factory unit on my YJ, if you don't have one get one.
get one for sure...I run a very nice one on my rock crawler but for my old junker yj I went to the u-pull-it junk yard and got a factory cooler off a grand cherokee for 5 bucks
I run two coolers on mine to deal with the Texas heat. I have a tube fin dual pass for the line as it leaves the tranny and a derale with fan at the return line. I bypassed the thermostatic switch and wired it direct with a toggle switch. I monitor with an autometer sending unit in the pan.
Cool thanks for the input, will be hittin the local boneyard to find one that will work for me.
that's heavy duty..my rock crawler has a temp gauge and never gets even close to redline here in south georgia
With the supercharger on long trips it develops alot of heat. During my last 4hr highway run to Austin (3hrs @75mph 104 degrees), when I hit stop and go in the city after 3 hrs on the highway my temps got up to 200. So I added the cooler and fan. Now they stay around 150/175 on hot days in traffic.
cool
1 - 10 of 10 Posts
