1 - 1 of 1 Posts
With the doors off I pulled int the garage, listened to a good song then turned radio off. I left the ignition in acc position overnight and it ran the battery down. The radio was off so not sure why.
But after charging the battery the radio was dead. No clock, nothing.
Checked all fuses with voltmeter with fuse installed, all were good.
Finally took it to the dealer. They first thought bad radio and it would need replaced.
But they took fuse out to check. Fuse was good but when they put it back in we heard a click and the radio worked.
Must nave needed a reset.
I thought would share this since all the searching I did mentioned bad fuses but did not see reset except one old post to remove battery cable which would also do a reset.
1 - 1 of 1 Posts
