93 yj wrangler 4cyl 5speed. when i first test drove it everything worked fine. after a trip home from georgia there didnt seem to be any problems. well me and a buddy were messing around in his back yard and 2wd wasnt doing it. so i put it in 4lo to get up a muddy hill. the 4wd indicator light came on but when i let the clutch out all i heard was a grinding from the transfer case. so i put it in 4hi and got up the hill. now the indicator light doesnt even come on when i try to put it in lo. im pretty sure im gonna need a new transfer case and found one on clist for 150$ with 95k miles. am i jumping the gun in replacing the tcase? could it be something else? im brand new to jeeps so any help is greatly appriciated. thanks
It may need linkage adjusted. Set screw on driver side of t-case holds rod connected to shift lever. If not set properly, you can't pull shift lever far enough back to engage 4LO.
