1 - 9 of 9 Posts
Rock-Rubber
I would never swap the 42rle in. The 32rh is a great trans, and the AW4 is a popular swap as well although I have actually heard some bad things over the last year or for. Do your research. If you are simply trying to identify what transmission you have, the 3 speed 32rh has a lock up torque converter which can be confused for an OD or 4th gear.
Thanks fellows my brother has the car that i just bought and he thinks it has a four speed that why I was asking I will be picking her up next Friday week we are having a small problem with an oil leak on the trans with roadworthy seem to be leaking from a gasket , is the odrive operated bye switch or automatic ?
Stupid question just read the tread converter lockup so it built in to. Sorry ,,,,
The 98 TJ w/4.0l engine & 3 speed trans has a lock up converter that is activated electronically with a servo inside the trans. Gives the impression that it shifts into a 4th speed <> 45/50 MPH. Still it will only get like 17 mpg.
1 - 9 of 9 Posts
