I cant seem to get the jeep into 4wd low, i can get it into 4wd high but not low.
any comments or suggestions, thanks
change it manualy at the tcase to get it in 2wd. Then figure out why its having issue shifting in and out of 4wd. Its probly in the linkage.
You did mover the lever over to the right to get it down to 4L...right?
With the vehicle rolling at 2 to 3 mph (3 to 5 km/h), shift
an automatic transmission to N (Neutral) or depress the
clutch pedal on a manual transmission. While the vehicle
is coasting at 2 to 3 mph (3 to 5 km/h), shift the transfer
case lever firmly to the desired position. Do not pause in
transfer case N (Neutral).
NOTE: Shifting into or out of 4L is possible with the
vehicle completely stopped, however, difficulty may occur
due to the mating teeth not being properly aligned.
Several attempts may be required for clutch teeth alignment
and shift completion to occur. The preferred
method is with the vehicle rolling at 2 to 3 mph (3 to 5
km/h). Avoid attempting to engage or disengage 4L with
the vehicle moving faster than 2 to 3 mph (3 to 5 km/h).
Knows a couple things...
Is this a new Wrangler for you and you're having trouble shifting into 4Lo, or is this a new problem after having had no previous problem with shifting into 4Lo?
