So the roads around me , post storm are still pretty bad. However I do come across some dry roads that turn back to wet/ snow. How long can u safely drive in 4 WD on dry pavement without screwing up the transmission? Thanks
The Bad Guy
When you get to dry pavement switch back to 2WD. You shouldn't use 4WD unless they are completely snow covered.
I wouldn't risk staying in 4wd on dry pavement at all unless it's just a small patch here and there.
Just shift back to 2wd when on a stretch of dry pavement and back to 4wd for the snow.
Thanks. That's pretty much what I've been doing. I was thinking that maybe shifting too much might screw up the transmission.
Don't stay in 4H over 50. In fact, if I'm able to travel at 40 I don't need 4H. If you have dry/wet pavement then some snow you really don't need 4WD. I know it's nice to be able to use it because you have it, but the reality is over 95% of the time you don't need it and shouldn't use it.
