I am getting a higher pitched "Whirring" from under the hood when I drive in 4x, only when the clutch is out. It goes up and down with the idle.
I am also getting a low pitch "rubbing" sound when I slow from about 30mph to a stop also in 4x. Its coming from the front, I think.
Any ideas?
first thing to check is u joints. front d shaft, and front axle shaft u joints.
Hmmm, that was supposedly all replaced last winter. I guess I will have to look though:(
How do you tell when the axel shaft u joints are bad?
turn the wheels all the way one way, spin the tire by hand and watch the joint, and try to move the axle shaft at the joint. turn the other way to check the other. no movement should be there accept the spinning. nothing else
