4x4 Not Working!!!
10429 10
Hey guys have a big problem. My YJs 4x4 aint working. When I put it into 4HI and 4LO the transfer case locks but its not putting the power to the front wheels? any ideas?
1 - 11 of 11 Posts
Sounds like you might have a problem with the vacuum mechanism on your front axel.
First check your vacuum lines for a leak. You can google YJ vacuum diagram and that may help you understand what routes where. Even better if you have a FSM.
If you don't find a leak, search vacuum shift motor inexpensive fix on this site and that will give you some information on another thing to try.
We are currently getting pounded with snow so I believe the vac lines may have froze too...shes thawing in the garage and I'm gonna check all the vacuum lines and the motor on the axle.
make sure vacum lines are all attached and check vacum presure and if the transfer case is engaging and your vac lines are all good then check the acutator in the front axel and if it is the actuator its 60 dollars shiped for a rebuilt one on ebay
If you have the means to do so, you can lift the Jeep on jack stands, and engage the x-fer case in 4wd. If the front drive shaft is moving, then you have a disco problem. I fix mine a little different then in the write-uos here, but they all work. I would personally move the shifter fork over anyway. If that isn't the problem now it will be when you need it most.
Same problem here! Got all bundled up, hit the snowy road and got 5 blocks. Front tires not spinning at all. I ended up getting home on the business end of a tow rope. Please post what happens next. I'll also be googling in the meantime. Good luck.
hey so my vac lines were just full of water and crap and froze up. Gonna replace the lines and probably the motor on the axle cuz its 21 yrs old. haha.
LOCK IT or put a POSI-LOCK in and be done with it! and stop :banghead:
1 - 11 of 11 Posts
