I have an 89 jeep wrangler that is stuck in first gear. I have taken out the console and associated parts to get to the top of the transmission. there is 3 bolts that hold a plate on top for the shifter. I can not get thre shifter to pop out. Is there something I'm missing or does the round plate just twists out so I can remove the shifter to see what is worn or broken????
Follow the stick down to the bottom, there is a twist off holder. Push down on it and turn and it should pop right out. Haynes manual has a good picture. I just replaced the transmission on my 95 with a rebuilt the 89 and they are the same. but checked
shifter removal
The 3 bolts taken out and the shifter is held in by a plate that has no physical way of removing it and I'm stuck. HELP
same problem i also have to do upload.
can anyone please instruct me actually what is the exact and easy way to do the same.
please confirm and thanks in advance for information.
