Hi,
I am new to the group and looking forward to being a member. I can use some assistance in two areas. Sound system (am/fm/cd radio) and transmission repair.
Can someone recommend qualified shops or individuals to handle these items in or around Memphis, TN.
The Jeep is an 88 Wrangler with 402.
I have been told that I need a shift pin as there was a lot of slop in shifter and the pin came out of its slot and stuck vehicle in first gear. a mechanic was able to put it back, put suggested I replace the pin.
There is no radio in Jeep. It has was seems to a factory provided wiring hookup and an antenna wire under the dash, but no antenna. No speakers. I can use some suggestions at to the best antenna and over all systems.
Thanks in advance for help. DC
Welcome to the forum! Let's see some pics of your YJ!
I'm only qualified to answer your radio question, so here's my input...
Most any single den cd/radio/mp3/aux player will fit in the slot. You can go to Crutchfield: LCD TV, Car Stereo, Home Theater, Speakers, Digital Cameras and enter in your vehicle information then it will give you a HUGE list of options that will work. Once you pick what you want... shop around, because crutchfield is expensive. ebay stores or amazon are great if you want to shop on line. Hope this helps!
There are tons of Jeepers on here... and chances are someone will chime in with a solution to your problem with the tranny/shifter.
