I had a few hundred bucks in my play account and I figured I should blow it.
I bought a 50 Inch Eye-yourlife light bar to throw on top of the wrangler. The reviewers say seal it with RTV and you're good to go.
It didn't come with a wiring harness so does anybody know what gauge wiring I'd need for this 300watt beast?
I picked up a light bar and wiring from Maximumjeep.com . Fantastic products, their wiring kit worked out great for me.
eyourlife is what I have in 30" and seems to be holding up well for the few months that I have had it...didn't seal it at all and so far so good with no moisture or water inside yet
Eyeyourlife light bars are already sealed.
Not sure where you'd put RTV but you shouldn't need to. Might avoid direct power washing so you blow out a seal but typical rain and daily driving they seem fine.
I live in the Pacific Northwet and my 50" bar has been in the rain and snow for a year now, with no fog or leaks.
For the wire size question you first need to find the amperage of the circuit. Take the wattage and divide by the system voltage. 300/12 = 25A. The go find an ampacity chart which will tell you what guages of wire are rated for. In this case you will want at 10AWG or lower
