I'm considering doing a spring swap with some take offs locally. Currently I'm at 13\55 (it might have been 54, but pretty sure it was 55). The take offs are 17/58 and 59.
I can't find it again, but somewhere on here I read someone had different part numbers in the rear with the higher on the passenger side.
Why would the rears be different? Is this common? Would it be anything to be concerned about?
Also, reading through the multitude of threads on the subject, I should expect roughly 1-1.5" of lift? Thinking of adding spacers to level it out and target the 2" mark.
Thanks
it can happen that the rear has different coils but it is rare. yes put the higher number on the passenger side to fight the jk lean.
