6 lug dana 44 to 5x4.5?
what would i need to convert it?
i found a dana 44 with a detriot locker and 4.30 gears for $200 is that a good deal? thanks in advance
Knows a couple things...
You need new axle shafts, the flange at the end of the axle shafts is what determines your bolt pattern. Superior Axle & Gear is a good source. Know what the spline count and length of your existing shafts is, you'll need the new axle shafts to match what you have now so they'll fit the axle housing and Detroit Locker properly.
