1 - 11 of 11 Posts
I swear I searched for this!
I have the Teraflext Ant Mount behind my Right Turn signal on my TJ. I sanded the holes so there is no paint.
I ran a test wire from my Neg Battery Terminal to check for ground.
I am getting 7 Ohms. (I am used to working with Kilo and Mega Ohms)
I 7 Ohms too much from this mount? Do I need to run an additional ground wire?
Thanks for your time.
-johnnie
ps - My SWR readings were below 1 on Chnl 20? Makes me wonder if the SWR meter went south?
Thanks Batjeep! There is no rush so I will keep trying to get that resistance down.
Thanks again.
Verify good common ground to battery, then mount to frame. See which half its in.
7 seems a tad high to me too. Good multi meter?
It is a "higher end" digital multimeter. But it is 7-9 years old.
I did notice one of the braided grounding straps near the fuel tank was broken. Need to fix that!
I will be under the Jeep again tonight.
I will keep y'all posted.
Thanks again!
Question. Why did you connect the wire to the battery? That may be a source of impedance added to the circuit when you were testing from the antenna to ground. Just wondering.
Discussion Starter #7
I was trying to find a know good ground. I did not have anyone there to hold the MM to the frame while I wes testing the inside of the hole where the ant mounts.
Should I test from the Mount to the frame?
Thanks fellas!
Like americonium said, test the mount (or better yet shielding collar) to frame, then test neg batt terminal to frame. The sum should be 7 ohms, and you should be able to tell if it is the mount or battery that has the resistance going to the frame. Then we can fix that.
Discussion Starter #10
Well fella's - I hooked up my new CB, Ran the Coax and tested for SWR.
Readings right around 1.0 on my middle channels. Below 1.5 on low and high channels!
One thing I forgot to do was check resistance again :facepalm:
I think Americonium may have been on to something regaring my "test ground to battery."
Just wanted to update and say thanks again folks!
I got my ears on now!
Sounds great! Typically when your standing waves are performing that well there is no bottleneck, or resistance spot, in the ground circuit - it is behaving as a "solid piece" to conduct the radiation. Never hurts to check, though.
1 - 11 of 11 Posts
