by the numbers, that would be 10mm wider and 7.5mm taller. I don't see where that would be a problem, but i am not a suspension guy so I won't say 100%, just giving you how much bigger the numbers say it would be.
Thank you for your reply. I have seen the 255's stock on occasion, not knowing about the particulars with each model... I can get a good deal on new duratracs so I will be going for it...The majority of JK came with the 255/75R17s including some special editions of the Sahara (like my '17 Chief). Sahara models generally came with 255/70R18 tires. Both sizes are 32" tall. The 255s are only 3/10 of an inch wider and 1/2 inch taller. I doubt you will see much difference. If you want to go even a bit bigger,
As stated in the above, my Chief came with 255/75R17 tires on 17" x 7.5" factory wheels with 6" of backspace. (Almost all of the alloy JK wheels are that spec). I went with new wheels (17" x 8.5" with 5.2" backspace) with 285/70R17 tires. They are 1.3" taller and 1.5" wider than your tires. The height is ok unless you need a lot of articulation when off road, but the width will rub unless you either use spacers or change the wheels.
I wasn't going after the larger tires initially, my goal was the CJ Retro wheels. When I found out that the 285's would just barely peak out from under the flares (sidewall only, tread is still under) with the change in backspace, I thought the slightly larger tires would be good, and I don't regret it at all. They are also LR C as are your factory tires. Most of the 275s you see touted on here are almost all LR E which have stiffer sidewalls (because of the additional load capacity) which gives a bit stiffer ride.
Either way, you should reprogram your computer for the change in tire size although the 255/75R17s make only a 2% change in the speedometer and odometer, your shift points on your transmission are also affected. You can get the OBDII adapter and a Jscan app for your phone for about $60. You can also set the TPMS threshold down so you can run 30-31 pounds of air in the tires without having the TPMS nanny fussing at you. (I set mine to 25 PSI and run 31. If it alarms, I know I have a tire issue).
I have always done the 5 tire setup. The only reason that my tires have lasted this long is the 5 tire rotation (always clockwise)....I like the Duratracs and have them on my '03 TJ. I tried to get them in the 285s when I put the new wheels and tires on the Chief two years ago, but they were on serious back order. I waited for 6 weeks, but they were still 2+ months out. I opted for the BFG KO2s instead for the Chief. They were a little higher, but comparing the two, I would be hard pressed to choose one over the other.
I would recommend you also do the spare. While you can get by with the smaller spare as an emergency, keep in mind that it is now 7 years old and may be showing the effects of sun damage. You might want to consider going to a 5 tire rotation. I do that on both my Jeeps. With only putting a few miles on them (less than 3K on the TJ and less than 8K on the Chief) they will age out before they wear out.
I have always done the 5 tire setup. The only reason that my tires have lasted this lpong is the 5 tire rotation (always clockwise)....
I do not know that the reprogramming would be worth it for such a small size change. I really like the way that the Duratracks ride, I keep my pressure at stock, it just seems to work for me..I like the Duratracs and have them on my '03 TJ. I tried to get them in the 285s when I put the new wheels and tires on the Chief two years ago, but they were on serious back order. I waited for 6 weeks, but they were still 2+ months out. I opted for the BFG KO2s instead for the Chief. They were a little higher, but comparing the two, I would be hard pressed to choose one over the other.
The max tire size you can comfortably run on a stock setup is 33". The 255/75/17 measures 32", so this fitment will work just fine with what you are wanting to do with your JK.I have a 2016 2 door JK, 75th-anniversary edition, completely stock. Currently I have the stock 245-75r17 ties on it. I would like to upgrade to 255-75r17 tires. It is time for new ones, and I have seen other models of the JK with 255-75's. Will there be any issues with the 255's on stock wheels? Wheel well clearance is not an obvious issue, I am concerned with suspension clearance.
