Hello, I have an 85 cj7 with 4.2 and 4spd t176 trans . When I driving and if I let push the clutch in to coast/slow down I get a nice humming noise from my rear end pretty sure it's a bearing but my question would be which is most likely the culprit? It happens in gear clutch in or when I'm in neutral. Thanks for the replies.
Administrator
Not sure what to tell ya, i will assume it a model 20. I would guess and this is a big guess its doing it in neutral the pinon bearing... but not sure..
also are you sure its not just the a clutch issue?
Yea it does it if I just let off the gas and don't touch the clutch, if I push in the clutch , and if I shift into neutral and let the clutch out the only difference is when I put I take it out of gear I don't hear it transfer through the driveline and can only hear it in the rear end...
Probably pinion bearings so you might as well do the carrier bearings and axle bearings while you are in there.
I went through this same problem , did you change your lift ?if you did i would bet it's a drive line vibration due to an increased angle, when there is no load on the drive line it ls able to rattle a bit, add a load and it stops . a bad rear end would always make a grinding or squeal sound .
Rear axle noise on deceleration is almost always a bad pinion bearing or really bad preload. The slack lets the pinion go rearward too far. The first question I would have is if the yoke was changed out with the driveshaft replacement? That axle uses a crush sleeve and once used it should be replaced to get the proper bearing preload with a new yoke.
