I used Ford Ex. 8.8 Rear disc brakes on my 86 CJ7 Dana 44 rear
1 I had to elongate the holes side to side
2 use teraflex spaces for axle shafts
3 redrill holes to 5 on 5 1/2 and center hole
4 add 1/4" spacer inside the rotor.
5 TJ Rubicon wheel studs
6 TJ Rubicon combo valve + one adt on brake line
7 use saddles for Ebrake cables
8 modify Ebrake shoes to clear the studs
Right off the bat you get benefits stopping in wet conditions. You also get much better emergency braking with discs vs drums. And I feel a bit more control over your stopping which can make big differences. Also if you have bigger tires then discs can help quite a bit. I plan on doing thebdisc swap for my AMC 20 once I get the single axle shafts.
yea that sounds worth it... I would definitely have a lot of research to do before getting into that though. Most I've ever done was change brake pads lol . And what do you mean by AMC 20? You need different shafts to change brake over brakes?
dirt road inspector
I replaced the two piece axes with Warn axles with locking hubs so I could flat tow. Also stitch welded the tubes to the diff housing. The hubs would not take the torque generated by the 401 V8. I did replace the front D30 with a D44.
