88 yj dies when it gets warm
i have a 88 yj 4.2 and after it gets warm (3 - 5 miles) it dies and it will not start for hours later. it acts like it is not getting any fuel. i put a new filter and pump on it replaced the carb with a webber, tune up new dist., coil wires etc..droped gas tank cleaned it put filter in tank. and it still dies. does any one have any ideas how to repair.:banghead:
Is there anything hot next to the fuel line? I saw some people mentioning gas being heated to the point it causes "vapor lock".. GL
Are you getting spark at the plugs?
If not then I would be checking the emc. Let me know.
If so if you pour a little fuel into the carb when it stops running will it start and run for
a few seconds?
If it will then you know you have a carb/fuel problem.
I had this happen in my old volvo.. i'd be driving home from work and it'd just die while driving on a busy road.. my fuel lines where shot.. try that!
