hey guys my 89 yj driver side turn signals don’t work when my headlights are on and most my gauges don’t work at all and the they flicker on and off..any idea?
Retired Moderator
:welcome: to the Forum..:wavey:
Do you mean your gauge lights don’t work? Everything may be caused by the same problem, but my money is on a short or corrosion in the taillight bulb socket sending taillight filament power to the turn signal filament. If that light is brighter than the other side it’s a pretty strong indicator.
The gauge light problem is probably due to a bad headlight switch.
Welcome to the Forum johnnyray37,
NH2112 suggests everything may be caused by the same issue. I agree, but I suspect a bad ground or a shorted bulb filament. First grounds to clean are on the inside of the grill panel, one near each headlight.
Good Luck, L.M.
