1 - 1 of 1 Posts
Just typed this out for a guy on another board, figured I would post it over here for future reference if anybody ever needs the power distibution center connector pinouts
1992 YJ
A1 BL/RD PARKING LAMPS
A2 VT/OR REAR WASHER PUMP
A3 BR/RD RIGHT TURN
A4 NOT USED
A5 NOT USED
A6 NOT USED
A7 GY/BK BRAKE WARNING SWITCH
B1 BR/WT DAYTIME RUNNING LAMPS
B2 WT/BK DAYTIME RUNNING LAMPS
B3 NOT USED
B4 WT/OR SPEED SIGNAL
B5 BK GROUND
B6 GY/BK BRAKE BULB CHECK
C1 WT/OR SPEED SENSOR
C2 GY/BK LEFT TURN
C3 NOT USED
C4 GN/OR EMMISIION MAINT. INDICATOR GROUND
C5 GN/RD CHECK ENGINE IDICATOR GROUND
C6 WT/BK BACKUP LAMP SWITCH/ AC RELAY
D1 LG/BK FOG LAMP
D2 NOT USED
D4 PK/WT HAZZARD FEED
D5 WT/YL IGNITION START AND RUN
E1 WT/RD HI BEAMS
E2 LB/BK HI BEAMS
E4 RD/OR HEADLAMP SWITCH FEED
E5 NOT USED
F1 NOT USED
F2 NOT USED
F3 VT/WT WINSHIELD WASHER PUMP
F4 NOT USED
F5 NOT USED
F6 BR UPSHIFT SWITCH
G1 NOT USED
G2 NOT USED
G3 GY/OR HORN
G4 RD/YL FUSE BLOCK FEED
G5 GN STARTER RELAY/CRANK
G6 GY/OR HORN REALY
H1 LG LO BEAM
H2 NOT USED
H3 NOT USED
H4 PK IOD BATTERY FEED
H5 LB/YL STOPLAMP SWITCH
H6 OR TACH SIGNAL
1989 XJ 4.0
A1 GY/BLK LEFT TURN
A2 BK/LB UPSHIFT INDICATOR
A3 LG/BK WINSHIELD WIPER
A4 LG/YL ANTI-LOCK PUMP FEED
A5 NOT USED
A6 RD/WT BATTERY DRAIN DISSCONECT
A7 NOT USED
B1 DB PARKING LAMP FEED, LIGHT ON BUZZER
B2 VT/WT WINSHEILD WASHER PUMP FEED
B3 DB/WT WINSHEILD WIPER HIGH SPEED
B4 NOT USED
B5 BK/YL FULL TIME INDICATOR LAMP
B6 YL IGNITION SWITCH 1-1
C1 BK/RD PART TIME INDICATOR LAMP
C2 YL/BK BACKUP LAMP FEED
C3 GN/WT TACHOMETER
C4 PK/BK FUEL PUMP FEED
C5 BR/WT REVERSE SWITCH
C6 LB OIL PRESSURE INDICATOR
D1 RD BATTERY
D2 VT COOLANT TEMP
D4 RD BATTERY
D5 LG DIMMER SWITCH LO BEAM
E1 ACCESSORY POWER
E2 GY HORN RELAY
E4 WT DIMMER SWITCH HIGH BEAM
E5 OR/BL BLOWER MOTOR FEED
F1 NOT USED
F2 BR RIGHT TURN
F3 BK BRAKE INDICATOR W/O ABS
F4 BR ACCESORY IGNITION EXPORT
F5 GY/RD BRAKE INDICATOR
F6 VT/WT WASHER FLUID LEVEL SWITCH FEED
G1 LG/BK FOG LAMP SWITCH
G2 TN/GN BATTERY INDICATOR LAMP
G3 WT/BK WINSHEILD WIPER LO FEED
G4 BK INSTRUMENT PANEL GROUND
G5 TN/BK A/C REQUEST
G6 OR 1-3 IGNITION EXPORT
H1 LG A/C THERMOSTAT SWITCH
H2 DG IGNITION SWITCH START
H3 TN/BK WINSHEILD WIPER/ PARK FEED
H4 LG/BK A/C MODE SELECTOR SWITCH
H5 VT/OR REAR WIPER WASH SWITCH
H6 WT/OR LOW WASHER INDICATOR
1 - 1 of 1 Posts
