hi guys,
so recently I've had problems with my transmission. After driving for more than a couple minutes, it will not shift into 4th gear. all other gears work fine with no real grinding or meshing noises. any ideas on what could be going on?
So it goes into 4th during the first couple minutes, but not after engine and transmission gets warmed up?
What about idling at a light or in a parking lot, can you shift into 4th then?
What about if you shut it off after it has warmed up, can you shift into 4th then?
When was the transmission gear oil changed last?
What about the clutch, pressure plate and throw-out bearing?
I am assuming you have a hydraulic clutch? How's the fluid level when cold and when warm?
Is it an AX5 or AX15 ?
