I have a 93 with the internal slave cylinder. I think the slave cylinder is failing which is causing my clutch issues, but I wanted to try to bleed it first. When I went to open the bleeder screw I was not very careful and I broke it off. Does anyone know where to get a replacement bleeder screw?
Thanks
as long as it is just the screw, you should be able to get it at parts store(napa).if it is the line i have been told you have to buy new master cylinder(i had to)!!!
fi you have to replace the internal slave cylinder you might as well replace the clutch to while you have it all open it's not much more for the whole clutch kit including it
