I have seen a few different size bolts referenced in other threads, and I want to make absolutely sure before I go to Lowes that I am getting the right stuff...
The passenger side front seat belt buckle assembly, where it screws into the tub ... what size is the bolt I need for that?
In addition, what else do I need? Nut for underside of tub, washers, etc.?
Many thanks.
That is an odd detail that may not be readily available. When you are at lowes, pick up a set of torx drivers for a 3/8" ratchet and pull out a bolt and take it with you.
If memory serves they are M10 bolts that are 1.5" long, I think you need a T30? Driver....but it has been about a year.
No washers or any other hardware required, the bolt is a button head that threads into a body tub welded nut.
