Will it work? I blew up my 94 so I found a 89 motor for $150 with 147k. I have my old block an fuel rail. So I'm pretty sure I'm gonna have to swap intakes, but what else with I need to do? Like motor mounts, tranny an splines an stuff like that?
Thanks
you shouldn't need to change anything as far as mounts and transmission go however $150 sounds like a lot of $$$ for a 4 banger with 147K miles on it. I sold my '95 4 banger with transmission, harness, and ECU for $400. You could probably pick up an inline 6 for that price and that amount of miles.
What should I offer him? 100$? I'm just trying to get a motor back in it an be able to drive it again, I'm not really looking for more power, atleast for now
Honestly thats up to you and I hear you but you would be swapping from fuel injection to carburetor unless you only strip that motor for parts to rebuild yours.
I honestly dont know enough to tell you much more than that but I wouldnt go that route If I was in your position. Maybe post up on the tech question side and someone with significantly more knowledge than I could help direct you further :)
No. All YJ 2.5L models are fuel injected from the factory. 1987-1990 models use a Throttle Body Injection unit (one injector inside of the throttle body) and 1991-1995 use a more standardized Multi Port Fuel Injection setup.
You will need to swap your 1994 parts onto the 89 engine but otherwise it should theoretically work.
A bigger engine swap would necessitate swapping more than the engine.
Hey guys, I'm Rebuilding a 1988 Jeep Wrangler YJ.
Anyways I Need help buying a new engine, fuel injected. I currently have an 88 with a carburetor, running a 258 4.2 liter straight 6.
My question is what newer year of a fuel injected engine can I put in without having to make major mods. Like can I go from an 88 to a 90, 91, 92, 94, 95, etc you get the point. Price is not a problem, I Just want to swap out the carburetor for fuel injection. Also I am not interested in fuel injection kits.
Thanks any suggestions will be greatly appreciated.
-Jaxs
jaxs, if you google jeep 4.2 fuel injection conversion you will find complete TBI kits that aren't smog legal for around $1200 an links on piecing a kit together from used parts. Some buys report great results scrapping the stock 4.2 carb set up an getting a motorcraft 2 barrel carb an GM hei style distributor.
