1 - 20 of 50 Posts
Hi Guys
Helping a neighbor work on his Jeep and have run into a problem.
Going from a 93 2.5 to a 94 4.0.
Have the swap all installed. Used a donor vehicle so we got the harness and computer along with trans and transfer case.
Engine cranks fine but no spark. Throws an engine code of 54 which is "no cam position sensor signal".
We have changed the crank position sensor along with the ignition coil and the distributor off of his 2.5 which was running when we pulled it out with no luck.
Have cleared the code each time and it always comes back the same.
Have not traced all the wires but the harness looks to be in good shape.
Is their something simple we are missing?
Thanks for any help you guys can give.
Kim
At the bottom of my signature below there is a dropbox link with most of the FSM's of the various YJ years, look in the one that most appropriately fits the donor and scroll through the troubleshooting section for no spark diagnosis. I have no computers so an of little help other than offering up a few resource manuals. Good Luck.
Are you using the 4.0 distributor? And the sync (cam) sensor from the 4.0? Also are you using the any bit of the 2.5l harness?
Hi Guys
Kim
If I read this correctly, you're using the CPS, the coil and the 2.5 distributor.
Is that right?
Good Luck, L.M.
Started with the 4.0 Distributor until the diagnostic code. Got a new dis from AutoZone and had same problem. Was told AutoZone Dis was probably junk so got a reman from NAPA that had the same part number as the 2.5 so decided to use that one as that engine ran fine. Used a new cap and rotor in it.
No part of the 2.5 harness was used. Unplugged everything and left the harness intact on each engine as we pulled them.
All connections were made on the install of the 4.0.
Is that right?
Good Luck, L.M.
CPS and 2.5 distributor.
Plugged the 2.5 coil in to see if that would eliminate the problem but it didn't so we are still using the 4.0 coil.
2.5 and 4.0 distributor have the same part number at NAPA.
Seems the only difference is the cap.
Rotor is also the same.
Kind of leaning toward a bad ECU but as this is the first time doing this maybe we missed something simple. Unfortunately he didn't hear the 4.0 run before he bought the donor vehicle.
Thanks for the help.
Kim
Also have checked all fuses and relays in engine compartment.
Is there a fuse anywhere else that could be the problem?
Kim
Just looked it up on rock auto and the cam sensor is the same for 4.0 and 2.5. So I guess you are good. I’d trace the wire. Unplug the cam sensor and pcm. Check continuity to make sure the cam sensors wires to the correct pins on the pcm.
I'm going to assume it does as we got the computer from the donor vehicle along with the harness.
Thanks again.
Kim
Thanks again.
Kim
I think that is a bad assumption to make, especially when your next step is replacing the pcm. The engine and wiring harness is a donor so you don’t know the full story. The wiring harness is 25 years old. It has been moved more in the last month than the previous 24 years. Also the pcm recognizes that something is wrong with the cam sensor. A small break in a wire will cause your code.
Very good point.
Will trace the wires just to be sure.
Kim
Is a 4 cyl distributor actually supposed to work in a 6 cyl engine?
Good Luck, L.M.
One thing that would also be worth checking is the 8v power feed coming to the Cam sensor. When you unplug the cam sensor and check on the harness side connector. There should be an orange wire coming in. Check for 8V on that pin. You can even check for 8v by putting read lead on that orange wire pin and black lead on wire that is black/light blue stripe. Key needs to be on.
They have the same part number when you go to replace them.
Only difference is the cap.
Kim
When I first started working on cars in 1960, all gasoline powered cars had points & condensers in the distributor. A 4 cyl distributor shaft would have a 4 lobe cam to open and close the points. A 6 cyl distributor shaft would have a 6 lobe cam to open and close the points.
With that in mind, I would have never considered attempting using a 4 cyl distributor in place of a 6 cyl distributor.
I looked on the NAPA and Rock Auto sites and indeed, the re-man distributors have the same part number. When you scroll down the NAPA page with the re-man 4 cyl distributor it states it's for a 6 cyl.
Both NAPA and Rock Auto have new OE distributors and they have different part numbers.
I don't dispute that a 4 cyl and a 6 cyl distributor can be interchanged because I just don't know enough about the innards of electronic distributors.
For peace of mind, I'd examine the area on each distributor shaft that activates the sensor. If they're the same, well, carry on. If they're different, be sure to reinstall the 6 cyl distributor.
In any case, I would carefully determine the compression stroke of #1 cylinder. Some home mechanics put a piece of tissue paper in #1 spark plug hole and crank the engine over. As the tissue paper blows out, that should be #1 compression stroke. I prefer to remove the valve cover and watch for #1 cylinder intake valve to actuate as I crank the engine over by hand. Only then would I look for #1 cylinder TDC on the crankshaft pulley and install whichever distributor that would work best. Bear in mind that the rotor points in a different location after installing the distributor than it points to just before you drop it into place because of the angle of gear at the bottom of the distributor shaft.
Once the distributor is in place, make sure that the rotor points to #1 spark plug wire. Your service manual will have a picture of what it's supposed to look like with the distributor properly installed.
Did you actually hear the 6 cyl engine run when it was in the donor vehicle?
If so, did it run well?
Keep us posted, I think you're close to getting this thing running. I'll bet it's something that'll be an easy fix once it's discovered.
Good Luck, L.M.
Discussion Starter · #15 ·
Good Luck, L.M.
Thanks
Made sure each time I removed the dis it was at no. 1 cylinder.
Unfortunately he didn't hear engine run before he bought donor as there was no gas tank installed.
I have inspected the wires and can't find any breaks yet.
I'm leaning toward the ECU which he may have to change anyway as we're in Ca. and from the number on the ECU it may not be Ca. compliant for smog.
Thanks again.
Kim
Hi Guys
Kim
You had a code for a cam sensor and replaced the crank sensor? How about replacing the cam sensor that has show a code
Discussion Starter · #17 ·
Replaced the distributor with one we know works.
Cam sensor as far as I understand is in it. If not I couldn't find where else one is.
Kim
Discussion Starter · #18 ·
Did this and not getting 8v as far as I can tell.
Didn't crank engine but looks to be a problem with the electrical supply.
Kim
Kim
Camshaft position sensor determines which cylinder is firing. Then it uses that information to sync the injectors with the ignition. The CPS is one of two sensors that if they fail, your Jeep will not fire the spark plugs or cycle the fuel injectors. Pretty much leaving your Jeep Wrangler sitting dead.
Where is the CPS Sensor located?
In the Jeep Wrangler YJ & Cherokee XJ, it is located inside the distributor on both the 2.5L & 4.0L.
Discussion Starter · #20 ·
Used 3 different distributors and have the same problem.
Last one is out of the 2.5 which was running so pretty sure it's not that.
Kim
1 - 20 of 50 Posts
