1 - 12 of 12 Posts
94 YJ, 2.5L stock 146,000 miles failed the damn state emissions test.... here in the metro Atlanta racket...
The only part it failed was the NOx...
Allowed 1163ppm failed with 1218ppm on the 25/25 test
Allowed 1273ppm failed with 2226ppm on the 50/15 test
Any and all suggestions, comments, etc. would be greatly appreciated...
I hate emissions testing. Im sorry for your results, but I've never had to deal with emissions.so it's something i never worried about being from michigan. Just wanted to send condolences. IMO, big brother has gotten too big. We the people, need to take back our country. And stop letting them run our lives.
Emissions here are dumb, it's only 2 counties state wide and the exception for old vehicles is any vehicle made before 1981, so my 87 yj isn't exempt yet. The funny thing is "Classic" cars are exempt. So In 2 years I can apply for Classic plates and magically become exempt.
Makes.
No.
Sense.
Is that fuel injected? I had a cracked exhaust manifold and it caused high NO readings, after I welded it up it passed. Check for an exhaust leak before the O2 sensor. A vacuum leak can also cause high NO readings.
Beaker, yeah it sucks here too, only a handful here.
V, definitely will check that out. I did happen to notice a faint exhaust smell today and yes it is fuel injected. Thanks for the input
I literally had the same problem 2 weeks ago with my 89. Failed bad put a new cat on with no muffler so it sounds badass now. Took to emissions and it passed flying colors. Almost as good as a new motor!
I've heard this too as I'm having the same problem in my 94 yj 4 liter 5 spd, too high nox reading in Stockton CA
Welcome to the Forum robhattenthetinner,
I'd check for exhaust and vacuum leaks first. Then the O2 sensor. If that gets your Jeep past the emissions test, you're done. If not, then it's cat time.
Let us know what works for you.
Good Luck, L.M.
1 - 12 of 12 Posts
