How do you remove the glove box? I have removed all of the screw's/nuts I can see. Do I need to drop the A/C unit to get to anything in the back? I am trying to replace the resistor for the heater/defrost motor which, I have read, is behind the glove box. Please help.
Doug
In behind the dash, where the grab handle is. There are 4 nuts, 2 on each side. I believe they are 10mm, but i could be wrong. You have to remove those 4 nuts to get the passenger side of the dash(plastic) to come off.
I just did mine. Remove the radio, to the right of where the radio is behind the dash plate were two phillips screws, and two others on the opposite side of the glove box. You do not need to remove the a/c unit, just need small hands. :popcorn:
