My son is looking at buying a 95 it has a new clutch and runs good they are asking $2,000. I have a 12 JK but dot know about older Jeeps is this a good deal and what should he look out for?
x2 since you're in Michigan. Crawl all up under that thing looking for rust/rot. Luckily the 95 has a little better rust prevention measures on the frame. Sounds like a good deal though. Make sure it drives and shifts smooth and make sure the 4x4 engages. Hell even if the 4x4 doesn't engage, it's usually a simple fix on the YJs, so talk him down a few hundred if that's the case. :thumb:The main thing, besides the obvious used car stuff, would be the frame rails where the springs are attached. Watch out for rotted out ends.
