Will the AX5 transmission out of a 1995 XJ fit into a 1995 YJ?
It should. Make sure that the t-case is not clocked too low. I believe the difference in actually with the t-case, not the bolt position on the back of the transmission.
I said this same thing once before and was told that it's the transmission that needs to be drilled but that's still no big job to do.
