1 - 20 of 26 Posts
Decided I should start a build thread to follow my progress. About 2 months ago I decided that I was gonna trade in my 08 F350 Lariat CCLB that I was in love with. So my wife needed a new car so I traded in the truck and got her a new car.
Found a guy looking to trade his Wrangler for a small car for his grandson. Great! Fixed up the wife's old car and traded for a 95 Wrangler 2.5l 5-speed, 4 1/2" suspension lift, 3" body lift, huge 35" toyo open county tires on ugly 20" rims, soft top with half doors, 205,000 miles but ran pretty decent and not any bad leaks. Well it's been 2 months almost and I've done a lot of work already.
I'll try to get photos up and more info after work.
Discussion Starter #2
Alright so here are some photos from when I got her. Hopefully this photo thing works.
cool. What does it need?
I use photobucket, mainly because thats where ive always gone, but the interface sucks.
Well it needs nothing really but its getting a lot! My wife already hates that she ok'ed me getting it.
Thanks for the idea of photobucket, ill give it a try.
Discussion Starter #6
Here is when I brought her home and put some Hella lights on right away.
Discussion Starter #7
I hated the rims and tires on her. They were big and just ugly to me to I quickly sold them and bought a set of factory rims off a '15 JK from a guy at work. The only problem was the rims were smaller and the tires were smaller so it sat kinda funny for a bit.
Discussion Starter #8
In the meantime I had a bit of an electrical issue with my dash lights so I spent an evening troubleshooting and fixing the dash lights. Turns out all the contacts on the back needed cleaned off and I replaced all the bulbs. Now they all work!
Discussion Starter #9
The next thing I did was look into why it had been running so rich. First thing to fix was the intake. The PO took out all of the air intake and just stuck a cone filter right on top on the throttle body. OK, whatever. well with the vibrations from the engine and just driving around it would sit right on the brake booster and fall off. So that had to go. I looked into buying a factory intake and an aftermarket cold air intake but didnt want to spend the money so I decided to make my own.
I used a 3" piece of PVC pipe, 3" 90 degree, 3" to 2 1/2" reducer and a 3" piece of flex coupling to secure it to the throttle body. I reused the cone filter on the other end. Painted it all black and done. Its not the greatest but it actually works pretty good and looks decent enough for now. Ill end up redesigning it in the near future to include the CVT and canister vent tube like the factory box did.
Discussion Starter #10
The next thing I did was a tuneup and headlights.
I Replaced the plugs, wires, cap, rotor, belt, idler pulley (PO ran the belt wrong and cut grooves into the pulley), and fixed some vacuum leaks.
The headlights that were in it were HID with red halos. They looked cool but once you turned the lights on you couldnt see the halo. I decided to replace them with blacked out LED headlights and it really changed the entire look of the jeep. I love them and think they are awesome. They put out so much light I rarely use the high beam.
Discussion Starter #11
Well I ended up getting some new tires from work. They came off a JK that had been traded in. The tread was kinda low for the miles on the jeep so we replaced them. Instead of throwing out the tires I snatched them up and put them on. 315/70r17 BF Goodrich KO. I think they look real good on the factory rims with my lift. Tread is 8/32 so I can get another 10,000 miles out of them for sure, plus they were free!
Discussion Starter #12
Next thing I did was fix the parking brake because I had none. Turns out there was an open recall still on my Jeep. Can you believe that! An open recall on a 1995 Wrangler, recall had never been done, and you could still get parts! Recall was for the parking brake assembly. Cool! So did the recall at work (I work for a Chrysler dealer btw). Still didnt fix the parking brake issue. Ok no big deal probably needs adjusted and some new shoes.
I decided while I was in there just to replace everything and service the rear diff. Good thing I decided to do that because most of the parts were either broken or missing. SO everything got replaced. Drums, shoes, hardware, wheel cylinder, axle shaft seals, everything! While I had the diff cover off I decided to paint it and the drums. Keep it looking nice and from rusting. The diff looked pretty good, fluid was black but no metal shavings or much flake so that made me happy. filled it up with some free fluid from work and now thats all good to go!
Discussion Starter #13
And now to get us caught up to today my wife was getting tired of it being dirty and cleaned it for me, inside and out! Doesn't look to bad for a '95 with over 200,000 miles.
Ive also installed mirror relocation brakets because my mirrors fold in every time you close the door. Dont bother with them, they dont work with the doors on, you cant see the mirror on the passenger side. I also replaced the missing driver side fender extension, added D-Rings to the front bumper and to the rear hitch.
Ive got on order a snap repair kit for the top, a new o2 sensor, turn signal lever and switch, clutch pedal pad, clutch kit, flywheel, and a used transmission. The trans is fine other than a few bad syncros so Ill put in the replacement and rebuild the original as a spare. Ive done all this in the last 2 months so I've got a ton of ideas and things I want to do to her so check back and I'll update as I go.
Cool. I gotta service my diff. too. be careful with that air intake. If water gets up to it, you could be in for a motor.
looks like a good starting point for a nice build.
Discussion Starter #16
Thanks! I need to do the front diff still. Next weekend I'll be putting in the new trans, flushing the transfer case and the new clutch.
Discussion Starter #17
Ordered a new set of bushings for the front track bar because the jeep was walking all over the road. Got some red Energy Suspension bushings from Autozone for $11 (have a commercial account there). All I have to say is holy crap those things were hard to get in there! I spent probably 3 hours fighting to get the old ones out and the new ones in. However they do look cool and driving the Jeep this morning was so much better! I wasn't all over the road with every little bump. So I ordered another set for the rear track bar and it should be in today so I can get it back on the Jeep. I'll remember to take pictures this time.
Discussion Starter #18
So this past weekend I was able to get the new trans installed at work with he help of a friend. The old one was a lot worse than I thought it was. The fluid was very milky and mostly water. The flywheel was also in pretty bad shape and needed replaced. So while everything was apart we replaced the rear main seal, flywheel, installed a complete clutch kit, and flushed the transfer case. I was worried about the t-case after seeing the trans but it turned out to be ok other than some dirty fluid. We also checked and greased all the u-joints and cleaned out the old grease in the front slip shaft. A couple of them are going to need replaced along with tie rod ends. Hopefully that will be soon.
i also installed the new bushings on the rear track bar. I hope to get it installed this weekend if the rain holds off.
I also took the top completely off for the first time to repair some broken snaps. Turns out the repair kit for my top requires you to cut hols for the replacement snaps. I wasnt too keen on doing this so I repaired what I could for now. I think I'm gonna end up buying a new top in the next few months. What is your opinion on a Spice colored top instead of Black? I think a Spice interior would look better with it but maybe later Ill change that out when I rhino line the interior.
i also got a quote to replace and paint the hood. Over $600!!! The hood apparently has already had some body work done to it and the guy said it would be hard to match it since it was starting to peel off. He would have to sand the entire hod down, redo the old body work and fix the other dents before he could paint it. Im going to try and find another hood myself and may try my hand at some body work and painting on the current hood to save money for other projects.
Speaking of other projects, I'm also hoping to start on another project for the jeep this weekend as well with a friend. We are designing a storage system for the back since I took out the seats and stuff. This will house all my gear for off-road and recovery and also hold some rescue equipment for responding to emergency calls for the fire dept.
Discussion Starter #19
Quick update. It rained all weekend while I was home so nothing really got done. I did take the steering wheel off to replace the turn signal switch. Turns out it was fine. so i began troubleshooting why my left signal worked fine but wouldn't turn off after turning the wheel and my right signal would turn off if you looked at it funny, hazards worked fine. Then my right stopped working all together. Bad bulb or socket, didn't know. So I went and bought new LED bulbs because the back bulbs were already LED and new led turn signal relay thingys. Guess its a bad socket because half the time it doesn't work, wiggle the bulb it works. Well apparently I messed something up because now nothing works... turn signals don't work at all, neither side will turn off once you turn the wheel, found out the right side marker/turn signal socket and wires are completely missing, hazards don't work... idk! Anybody have any ideas on that please let me know! I guess I have to track down some new sockets for the front and side signals now. YAY!
Near and dear machine to me. Had a '95 Rio Grande for 14 years... Kids and a move to Europe (not in that order) has us with a JKUR now, but this is fun to read.
Oh, lose the 3" body lift if no one has mentioned- it's a REALLY bad idea in the YJ. I read a long time ago the tub can crack and the tallest body lift you want to do is 1".
Best of luck and enjoy.
1 - 20 of 26 Posts
