I am wondering where the oil pump is located on my '95 wrangler YJ. It is the 2.5l 4cyl engine. I had heard that there are some pumps located on the outside of the motor? Or is it up inside the oil pan? Thanks
You are going to have to drop the pan. Might as well, you'll be able to tell if its the pump or a bearing then. Pretty easy to do, drain oil, drop starter and remove bolts on the pan.
