Rookie jeepster question...should the turn signals go off on thier own after turn? I've had cars that didn't because the switch was bad. But it was usually only one side, neither canceling on my jeep.
when you are stopped try turning the wheel all the way to either side and see if they return, my 95 YJ does
Yes they should cancel.... These are the cancel springs in the column.They break. Takes maybe 10 minutes to change with proper tools and the parts are less than 50 cents, no joke... You have to pull the steering wheel and remove the lock plate to get to them..
