I have a 95 YJ currently running with 1" wheel adapters from Integrity Automotive and i got Stock JK Wheels 16x7. I wanted to know if i should go with 1.5 or 2 inch wheel adapters. I dont go off roading with the jeep and its more of a leisure ride more than a DD. Any feedback would be great
The wider you go the more prone you are to wearing out parts in your axel, I personally will not use them at all. I had them on an xj to gain more clearance and my tire fell off twice with no warning, make sure u keep them tight
I'm surprized you need spacers with 7" wheels, how wide of tire are you running? Before I add spacers I put a couple of washers under the steering stops. This will increase your turning radius, but so will adding spacers. If adding washers does the trick, it will be a lot easier on your front end then moving the weight outward. Many use spacers and claim no negative effects, I personally don't care for them.
Note that the OP said adapters. From YJ bolt pattern to JK bolt pattern.
I'm assuming the adapters also add width since he asks about 1" or 2". If possible I'd go the thinest adapter/spacer available for the reason above.
