1 - 1 of 1 Posts
i used to have a 00 4 cyl, the head was amazing, with a soft top and slider upper windows. not even really drafty.
now i have a 97 4 cyl hard top and normal plastic upper windows, the heat is eeehhhh,, it keeps it luke warm. ] i did new t stat, flush the heater core, ( i have no restriction ) the temp stays just under 210, where my 00 was always right at 210, and i used the same 195 stat, is the heating system different on the 97 like everything else then from a 98 or 99+?
im about to get a 97 6 cyl, as i expected to have the same problem?
my other questions,
now i have not seen a 97 with momentary wipers, tilt column, acc position on the ign., and the heat mentioned above,
are you able to take the momentary switch for the wipers from a 98 or 99 and will it work?
1 - 1 of 1 Posts
