check the metal tag...it should be the first number on the top right of the tag and then a space and then two numbers below it and thats your gear ratio...its the simplest way to do it...takes less than 30 seconds
Knows a couple things...
It'll be 4.10/4.11 for the front and rear axles as that's what came with the 2.5L/5-speed combination. By the way, 3.73 was never used in the '97 that only had 3.07, 3.55, and 4.10 as options. :)
