I have my TJ stripped all the way down to the frame. I am wanting to replace the frame. I can’t find a frame for a 4.0. I can find plenty of frames for a 2.5. So can I use the 2.5 frame? I know that I will have to change out the engine mounts. Is that the only difference?
Gas tank mounts? Can’t imagine there’s much difference in a TJ. That would have screwed with the production line.
Can’t you cut and weld sections?
Cheaper than freight most likely. Several decades ago, I used to make an occassional weekend trip from S. Georgia to Lynchburg. It is just a little over 600 miles.
Depending on what time you are driving down, avoid Atlanta on Friday afternoon at all costs. You can easily lose 4 hours in your trip in Atlanta on Friday evening. Many would be tempted to take I85 to Atlanta and then I20 over, but I would recommend I40 to I75 and pick up I59 in Chantaooga to Birmingham.
When I have to go North and hit the Atlanta area in the afternoon, I divert westward and go up on two lanes until I get to Rome and then get back on I75.
Reactions: Gottagofast
I avoid Atlanta ALL the time.....
You can lose WAY more than 4 hrs there...
