I've always suspected the passenger side rear was a bit low, did a bunch of measuring this evening and sure enough it is. Depending where I measure its 1/2 to 3/4 lower than drivers side.
Is this common? Just tired or bent coil?
RC 4" lift kit from previous owner.
Knows a couple things...
That's common, it happened to both of my TJs. It's caused by engine torque which ends up at the passenger side rear spring, fatiguing it. About the only fixes include a new spring or a spring spacer
I'll order a new set of rear coils I guess.
